Санитарно-технические способы обеспечения локального микроклимата в помещениях с высокой теплонапряженностью
Sanitary Engineering Methods for Providing a Local Microclimate in Rooms with High Heat Loads
M. A. Razakov, Senior Lecturer, National Research University “Moscow Power Engineering Institute”; Engineer, Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences
Keywords: high heat load, microclimate, working zone, air shower device, air distribution unit
Providing a local microclimate in rooms with high heat loads remains an important sanitary engineering challenge for industrial and municipal facilities. This issue is particularly important in working zones occupied by personnel temporarily or periodically, where general ventilation does not always provide effective protection against excess heat, convective airflows and harmful emissions. Such facilities include, among others, machinery halls of municipal sewage pumping stations, where comfortable and safe conditions must be maintained directly in the work area during the repair and maintenance of pumping equipment. Therefore, the development and improvement of local air shower devices, including mobile, semi-stationary and slot-type air distribution units adapted to specific technological processes, remain relevant.
The article provides an overview of Russian mobile and stationary air shower devices designed to maintain the microclimate in zones with high local heat loads. It presents non-standard slot-type air shower devices that can be used in working zones with temporary personnel occupancy.
Обеспечение локального микроклимата в помещениях с высокой теплонапряженностью остается одной из важных санитарно-технических задач для промышленных и коммунальных объектов. Особое значение эта проблема приобретает в рабочих зонах с временным или периодическим пребыванием персонала, где общеобменная вентиляция не всегда позволяет эффективно защитить человека от воздействия тепловых избытков, конвективных потоков и вредных выделений. К таким объектам относятся в том числе машинные залы городских канализационных насосных станций, где при ремонте и обслуживании насосного оборудования необходимо создавать комфортные и безопасные условия непосредственно в зоне выполнения работ. В связи с этим сохраняет актуальность разработка и совершенствование локальных душирующих устройств, включая мобильные, полустационарные и щелевые воздухораспределители, адаптированные к особенностям конкретных технологических процессов.
В статье представлен обзор отечественных передвижных и стационарных душирующих устройств для обеспечения микроклимата зон в помещениях с высокими локальными тепловыми избытками. Приведены варианты нетиповых душирующих устройств (щелевого вида), которые могут быть использованы в рабочих зонах с временным пребыванием рабочего персонала.
Статья опубликована в журнале “Сантехника” за №4'2026
- Воздухораспределение в помещениях
АВОК №4'2009 - CFD-моделирование микроклимата в общественных зданиях
АВОК №2'2026 - Системы воздухораспределения. Новейшие принципы
АВОК №1'2018 - Программно-аппаратный комплекс ООО «КРОНОС ГРУПП» – цифровое решение для управления отоплением в инженерных системах умного дома
Энергосбережение №3'2026 - Особенности проектирования вентиляции производственных цехов
АВОК №1'2020 - Умные оболочки зданий. Инженерные решения и влияние на архитектуру
Энергосбережение №3'2026 - Использование теплого плинтуса Charley в различных учреждениях
АВОК №1'2023 - Влияние экспозиционных перегородок на микроклимат выставочного зала: опыт филиала Третьяковской галереи в Калининграде
АВОК №4'2026 - Климат на пике технологического прогресса. Модельный ряд бытовых кондиционеров Kentatsu, сезон 2023
АВОК №2'2023 - Сплит-система серии KUMO: практичные решения для создания комфортного микроклимата
АВОК №5'2026
