Расчетная оценка влияния степени остекленности и климатических условий на остывание здания при авариях в системе теплоснабжения
Estimatedassessment of the influence of the degree of glazing and climatic conditions on the cooling of the building in case of accidents in the heat supply system
G. P. Vasilyev, Doctor of Engineering, Professor at SRI Moscow State University of Civil Engineering, Chief Scientific Associate at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; S. V. Sargasyan, Candidate of Engineering, Director of NOC TGV, SRI Moscow State University of Civil Engineering; V. A. Lichman, candidate of Physics and Mathematics, Head of Expert and Methodics Department of GBU Mosstroyrazvitiye, LLC IC INSOLAR; V. F. Gornov, Project Department Director at INSOLAR-INVEST LLC, Head of Laboratory at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; A. N. Dmitriyev, Candidate of Engineering, Professor at Russian Economy University of G. V. Plehanov; M. V. Kolesova, Deputy General Director at OJSC INSOLAR-INVEST, Senior Scientific Associate at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; V. A. Leskov, General Director at LLC INSOLAR-ENERGO, Senior Scientific Associate at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; A. S. Strongin, Candidate of Engineering, Senior Scientific Associate, Head of Laboratory at FSBI Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences; E. V. Abramova, Doctor of Engineering, Chief Scientific Associate at FSBE Scientific Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences.
Keywords:coefficient of glazing, cooling of the building premises, safety, emergency shutdown of heat supply, coefficient of thermal energy accumulation
Thearticle examines the dependence of the cooling process of a building after the heat supply is stopped on the degree of glazing, including in various climatic zones. The purpose of the study is the safety of residents in case of emergency situations with centralized heat supply. The threat of accidents in heat supply systems affects two thirds of the country's population, despite the fact that the technical condition of heating networks is of concern. The study is relevant in the context of housing and communal services and modern architectural trends aimed at increasing the glazing of buildings, and suggests measures to improve energy efficiency and safety.
В статье рассматривается вопрос зависимости процесса остывания здания после прекращения подачи тепла от степени остекленности, в том числе в различных климатических зонах. Целью исследования являются вопросы безопасности жителей в случае возникновения аварийных ситуаций с централизованным теплоснабжением. Угроза аварий в системах теплоснабжения касается двух третей населения страны, притом что техническое состояние тепловых сетей вызывает обеспокоенность. Исследование актуально в контексте проблем ЖКХ и современных архитектурных тенденций, направленных на увеличение остекленности зданий, и предлагает меры для повышения энергоэффективности и безопасности.
Безопасность является главным требованием, предъявляемым к строительному объекту, в особенности если речь идет о жилом доме. Но есть аспекты безопасности, на которые обычный жилец МКД повлиять никак не может. К этой категории относится, в частности, система централизованного теплоснабжения, от надежной работы которой, учитывая разнообразие климатических условий нашей страны, зачастую зависит не столько комфорт, сколько безопасность человека.
Про проблемы отечественного ЖКХ написано уже немало, и перечислять их в данной статье нет необходимости. Приведем лишь несколько официальных фактов, указанных в распоряжении Правительства РФ № 3268-р2:
• в домах с центральным отоплением проживает 67 % населения страны;
• протяженность тепловых сетей составляет около 170 тыс. км. Из этого числа нормативный срок превышен более чем у 60 %;
• по состоянию на конец 2020 года доля тепловых сетей, нуждающихся в замене, достигает 30,8 %. Учитывая, что каждый год аварийными признаются около 3 % сетей, а ремонтируется только порядка 1–2 %, на дату публикации данной статьи доля нуждающихся в замене тепловых сетей может быть еще выше;
• ежемесячно на объектах ЖКХ происходит в среднем 6 000 происшествий.
Как видно из представленных цифр, угроза безопасности, связанная с потенциальными авариями в системах теплоснабжения, напрямую касается двух третей населения страны, а учитывая техническое состояние сетей, возможность ее реализации оказывается не так уж и мала.
Рассмотрим влияние климатических условий участка строительства и степени остекленности здания, а именно многоквартирного жилого дома, на способность последнего сохранять тепло в случаях аварийных ситуаций в сетях и на источниках теплоснабжения.
Материалы и методы
Действующие нормативы предусматривают ситуацию, когда подача тепла в дом прерывается вследствие аварии в системе центрального теплоснабжения, и содержат требования, которые в основном сводятся к недопущению снижения температуры воздуха за время устранения аварий ниже определенного минимального уровня. Таких документов несколько: постановление Правительства РФ № 354 (далее – ПП РФ № 354)3, СП 60.13330.20204, СП 124.13330.20125, СП 253.1325800.20166, но в них данное требование сформулировано с некоторыми отличиями. В настоящей статье будем опираться на требования ПП РФ № 354, где сказано, что температура воздуха в жилых помещениях в течение 16 часов с момента прекращения подачи тепла не должна опускаться от нормативной ниже 12 °C.
Дальнейшее рассмотрение будет выполняться на примере базового дома, в качестве которого рассматривается проект конкретного МКД, построенного в Москве. Основные характеристики базового дома представлены в табл. 1, а площади и приведенные сопротивления теплопередаче основных элементов ограждающих конструкций, используемые в расчетах, – в табл. 2.
Предлагаемая теоретическая модель процесса остывания основана на принципах, изложенных в [1, 2]. Внутренняя температура принята в соответствии с ГОСТ 30494–20117. При этом в расчетах учитываются:
• трансмиссионные теплопотери (СП 253.1325800.2016, СП 131.13330.20208, СП 50.13330.20249 и СП 230.1325800.201510);
• инфильтрация (ГОСТ 31167–200911);
• бытовые теплопоступления [3];
• наличие внутренних перекрытий и перегородок (ISO 13790:200812), мебели, внутренней отделки и предметов в помещениях.
Анализ полученных результатов
Влияние степени остекления
Результаты оценки влияния степени остекления f на температуру внутри помещения при отключении отопления в период действия расчетной температуры наружного воздуха для условий Москвы приведены в табл. 3.
Температура воздуха в помещениях при f = 0,19 за 16 часов опускается до 13,2 °С, что соответствует требованиям ПП РФ № 354. Однако при увеличении коэффициента остекленности более f = 0,25 она становится ниже требуемого значения (12 °С). При f = 0,84 за 16 ч температура воздуха опускается до 5,5 °С.
Требуемое значение удельной теплозащитной характеристики для Москвы составляет кобтр= 0,155 Вт/(м3•0С). Из данных табл. 3 следует, что при принятых конструктивных и теплотехнических характеристиках можно строить МКД с коэффициентом остекленности не выше f ≈ 0,55. Увеличение коэффициента остекленности потребует улучшения теплозащитных качеств ограждающих конструкций, в первую очередь светопрозрачных.
Критерий безопасности по минимально допустимой температуре остывания при аварии теплосети оказывается более жестким, чем требование по удельной теплозащитной характеристике. Для выполнения этого критерия нужно не только улучшать теплозащитные качества ограждений, но и увеличивать теплоаккумулирующие свойства здания. А вот рост степени остекленности только усложняет выполнение данного критерия.
Влияние климата
Чтобы выяснить, как влияет климат на выполнение рассматриваемого критерия, гипотетически поместим базовый МКД в другие города России, расположенные в разных климатических зонах. Климатологические параметры, используемые в расчетах, определяются по СП 131.13330.2020 для соответствующего города, а значения приведенных сопротивлений теплопередаче наружных ограждений принимаются равными значениям, требуемым по СП 50.13330.2024 для каждого типа ограждений.
Значения температуры воздуха в помещениях спустя регламентированные 16 ч после прекращения подачи тепла приведены в табл. 4. Температура наружного воздуха в течение всего рассматриваемого периода соответствует расчетной согласно СП 60.13330.2020 и СП 131.13330.2020. Из табл. 4 видно, что спустя 16 ч после отключения отопления температура внутреннего воздуха изменяется весьма значительно в зависимости от степени остекленности как для городов, расположенных в теплом климате (Сочи, Краснодар), так и для городов, находящихся в умеренном (Москва) и холодном (Красноярск, Воркута) климате.
Требуемое значение внутренней температуры не обеспечивается в подавляющем большинстве случаев, причем для высокой степени остекленности (f = 0,84) данный критерий не выполняется ни для одного из рассмотренных городов. Аналогично данный критерий не выполняется ни при одном из рассмотренных вариантов остекленности для городов, расположенных в холодном климате (Красноярск, Воркута).
Конечно, на примере рассмотренного базового МКД, являющегося в значительной степени гипотетическим, нельзя делать далекоидущих выводов о том, что нормативные требования по обеспечению жизнестойкости многоквартирных домов при аварии на тепловых сетях в большинстве случаев не выполняются. Однако полученные результаты вызывают как минимум озабоченность. Авторы не располагают информацией о том, производится ли проверка по данному критерию в ходе экспертизы проектной документации, но полагают, что осуществление такой проверки было бы весьма полезным.
Выводы и рекомендации
Степень остекленности существенным образом влияет на способность здания аккумулировать и сохранять тепло. Выполненные расчеты продемонстрировали, что при увеличении коэффициента остекленности с 0,19 до 0,84 коэффициент аккумуляции тепловой энергии в здании уменьшается почти в два с половиной раза: с 100,2 до 42,4 ч.
Требования безопасности при аварии на системах теплоснабжения, установленные ПП РФ № 354, для рассмотренных условий выполняются только при остекленности f = 0,19 и 0,25. При бОльших значениях остекленности требования ПП РФ № 354 не обеспечиваются.
Расчеты, выполненные для 5 городов, находящихся в разных климатических условиях, показали, что требуемое значение внутренней температуры для высокой степени остекленности (f = 0,84) при выбранных конструктивных решениях рассматриваемого дома не выдерживается ни для одного из рассмотренных городов. Для городов, расположенных в холодном климате (Красноярск, Воркута), данное требование не выполняется во всех рассмотренных вариантах остекленности.
По результатам исследования может быть рекомендовано проведение на стадии проектных работ расчетной проверки соответствия принятых объемно-планировочных, конструктивных и теплотехнических решений здания требованиям безопасности, установленным ПП РФ № 354.
Данная тема представляется крайне важной, особенно учитывая тревожное состояние коммунальной инфраструктуры во многих российских регионах и тенденции в современной архитектуре, направленные на повышение степени остекленности фасадов как общественных, так и жилых зданий в любых климатических зонах.
1. Соколов Е. Я. Теплофикация и тепловые сети: Учебник для вузов. М.: МЭИ, 2001.
2. Богословский В. Н., Сканави А. Н. Отопление. М.: Стройиздат, 1991.
3. Проведение комплексных исследований, оценка фактической величины бытовых тепловыделений для квартир в многоквартирных домах, построенных в 2016–2017 гг., при различных вариантах заселения и определение научно-­обоснованных требований к нормативному удельному потреблению тепловой энергии многоквартирными домами, планируемыми к строительству по программе реновации пятиэтажного жилищного фонда города Москвы. УДК 620.9:662.6. М., 2019.
1 Вклад авторов: все авторы сделали эквивалентный вклад в подготовку публикации. Авторы заявляют об отсутствии конфликта интересов.
2 Распоряжение Правительства РФ от 31 октября 2022 года № 3268-р «Стратегия развития строительной отрасли и жилищно-коммунального хозяйства Российской Федерации на период до 2030 года с прогнозом до 2035 года».
3 Постановление Правительства РФ от 6 мая 2011 года № 354 «О предоставлении коммунальных услуг собственникам и пользователям помещений в многоквартирных домах и жилых домов».
4 СП 60.13330.2020 «Отопление, вентиляция и кондиционирование воздуха».
5 СП 124.13330.2012 «Тепловые сети».
6 СП 253.1325800.2016 «Инженерные системы высотных зданий».
7 ГОСТ 30494–2011 «Здания жилые и общественные. Параметры микроклимата в помещениях».
8 СП 131.13330.2020 «Строительная климатология».
9 СП 50.13330.2024 «Тепловая защита зданий».
10 СП 230.1325800.2015 «Конструкции ограждающие зданий. Характеристики теплотехнических неоднородностей».
11 ГОСТ 31167–2009 «Здания и сооружения. Методы определения воздухопроницаемости ограждающих конструкций в натурных условиях».
12 ISO 13790:2008 «Energy performance of buildings – Calculation of energy use for space heating and cooling».
Статья опубликована в журнале “Энергосбережение” за №8'2025
