Планирование объемов реконструкции тепловых сетей по целевому уровню отказов на примере крупной ТСО
Planning the Scope of Heat Network Reconstruction Based on a Target Failure Rate: A Case Study of a Large Heat Supply Organization
R. Yu. Rozhkov, Candidate of Engineering, Deputy Chief Engineer of Teploset Saint Petersburg
V. V. Khotyakov, Chief Specialist at the Research and Technical Center “Integrated Development of Engineering Infrastructure” in Saint Petersburg, Gazprom Promgaz
S. N. Kiryukhin, Candidate of Engineering, Associate Professor, Leading Specialist at Nevskaya Energetika
Yu. V. Yuferev, Doctor of Engineering, Professor, Project Manager at the Research and Technical Center “Integrated Development of Engineering Infrastructure” in Saint Petersburg, Gazprom Promgaz
Keywords: heat energy source, district heating system, heat networks, heat supply regulation, temperature schedule, maximum temperature testing, failure intensity, specific damage rate, heat supply organization, resource-supplying organization, combined heat and power plant, heating season, non-heating season
Based on an algorithm for forecasting changes in the failure intensity of pipelines depending on the service life of heat networks and the temperature of the heat carrier within the operational responsibility zone of a specific heat supply organization, a model has been developed to calculate the dynamics of changes in the average specific damage rate across the studied heat supply system depending on the established rates of heat network reconstruction.
Using this model, the required rates of heat network reconstruction were determined in order to reduce the specific damage rate to the adopted target value within the specified timeframe under different temperature schedules for heat supply regulation.
The results obtained make it possible to determine not only the scope of heat network reconstruction required to achieve the target damage-rate indicator, but also the necessary investment volume. Therefore, the proposed approach may be useful in the development and updating of heat supply schemes, as well as in the formation of investment programs for heat supply organizations.
На основе алгоритма прогнозирования изменения интенсивности отказов трубопроводов в зависимости от продолжительности эксплуатации тепловых сетей и температуры теплоносителя для зоны эксплуатационной ответственности конкретной теплоснабжающей организации (ТСО) разработана модель расчета динамики изменения усредненной по исследуемой системе теплоснабжения удельной повреждаемости в зависимости от установленных темпов реконструкции тепловых сетей. С помощью этой модели определены необходимые темпы реконструкции тепловых сетей для обеспечения снижения в заданные сроки удельной повреждаемости до принятого целевого значения при использовании разных температурных графиков регулирования теплоотпуска.Полученные результаты позволят определить не только объем реконструкции тепловых сетей для достижения целевого показателя уровня повреждаемости, но и объем необходимых инвестиций для этого и, следовательно, будут полезны при разработке и актуализации схем теплоснабжения и при формировании инвестиционных программ ТСО.
Статья опубликована в журнале “АВОК” за №5'2026
- Прогнозирование отказов тепловых сетей с учетом температуры теплоносителя и срока службы теплопроводов
АВОК №4'2026 - Что ждет Россию в будущем – котельные в каждом доме или все-таки централизованное теплоснабжение на базе теплофикации?
АВОК №2'2008 - Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №4'2019 - Износ и повреждение тепловых сетей. Решение проблемы качества и надежности энергоснабжения
Энергосбережение №5'2019 - Методология коррекции существующих графиков регулирования отпуска тепловой энергии
АВОК №3'2024 - Тепловая нагрузка систем отопления многоквартирных домов при двухставочных тарифах
Энергосбережение №1'2026 - Тепловые сети: эффективная эксплуатация
Энергосбережение №1'1999 - Примеры коррекции существующих графиков регулирования отпуска тепловой энергии
АВОК №4'2024 - Инженерное оборудование современных жилых зданий в Южной Корее
АВОК №7'2008 - Энергосбережение в системах централизованного теплоснабжения на новом этапе развития
Энергосбережение №2'2000
