Новая редакция СП 131.13330.2025 «Строительная климатология»
New edition of SP 131.13330.2025 “Building climatology”
N. P. Umnyakova, Doctor of Engineering. Sciences, NIISF RAASN, National Research University MGSU
M. V. Klyueva, Ph.D. geogr. Sciences, GGO im. A. I. Voeikova
V. A. Smirnov, Ph.D. tech. Sciences, Research Institute of Building Physics of the Russian Academy of Architecture and Construction Sciences, National Research University Moscow State University of Civil Engineering
Keywords: construction climatology, SP 131.13330.2025, cold period of the year, warm period of the year, air temperature of the coldest day, air temperature of the coldest five-day period, average monthly relative humidity
A new set of rules, SP 131.13330.2025 "SNiP 23-01-99* Construction Climatology," came into effect on September 9, 2025, replacing the similar SP 131.13330.2020. This set of rules is one of the main regulatory technical documents used in the design of building structures and buildings as a whole, heating and air conditioning systems, other engineering systems, etc. Climatic parameters form the basis for the development of virtually all regulations in the construction industry; they inform strategic decision-making in the design, construction, erection, and reconstruction of buildings and structures; and they serve as a determining element in the sequence of the vast majority of construction processes.
The revision of the SP ensures the use of more accurate and up-to-date climate data in the calculations of enclosing structures, heating, air conditioning, and other engineering systems, which allows for better adaptation of buildings to modern climatic conditions.
9 сентября 2025 года вступил в силу новый свод правил – СП 131.13330.2025 «СНиП 23-01-99* Строительная климатология», заменивший аналогичный СП 131.13330.2020. Данный свод правил является одним из основных нормативно-технических документов, используемых при проектировании строительных конструкций и зданий в целом, систем отопления и кондиционирования воздуха, других инженерных систем и т. д. Климатические параметры являются основой для разработки практически всех нормативов в строительной отрасли; принятия стратегических решений при проектировании, строительстве, возведении и реконструкции зданий и сооружений; служат определяющим элементом в последовательности подавляющего большинства строительных технологических процессов.
Пересмотр СП обеспечивает использование более точных и актуальных климатических данных при расчетах ограждающих конструкций, систем отопления, кондиционирования воздуха и других инженерных систем, что позволяет лучше адаптировать здания к современным климатическим условиям.
Ключевые слова: строительная климатология, СП 131.13330.2025, холодный период года, теплый период года, температура воздуха наиболее холодных суток, температура воздуха наиболее холодной пятидневки, средняя месячная относительная влажность воздуха
В 2024 году НИИСФ РААСН совместно с ГГО им. А.И. Воейкова провел работу по пересмотру СП 131.13330.2020 «СНиП 23-01-99* Строительная климатология». Следует отметить, что данный свод правил является одним из основных нормативных технических документов, используемых при проектировании строительных конструкций и зданий в целом, систем отопления, кондиционирования, других инженерных систем и пр. Климатические параметры являются основой для разработки практически всех нормативов в строительной отрасли; принятия стратегических решений при проектировании, строительстве, возведении и реконструкции зданий и сооружений; служат определяющим элементом в последовательности подавляющего большинства строительных технологических процессов.
Необходимость пересмотра Свода правил связана с тем, что в настоящее время наблюдается значительное изменение климатических условий, выражающееся главным образом в общем повышении температуры воздуха. Согласно Докладам об особенностях климата на территории Российской Федерации за 2019–2023 год, выполняемым НИУ Росгидромета, потепление климата происходило во все сезоны [1–5]. Наибольшая скорость потепления наблюдалась весной и составляла 0,63–0,66 °С/10 лет. Наименьшая скорость потеп-ления наблюдалась в зимний (0,4–0,48 °С/10 лет) и летний (0,4–0,41 °С/10 лет) периоды. В осенний период скорость потепления составляла 0,49–0,54 °С/10 лет. Годовые и сезонные аномалии температуры по территории России за 2024 год приведены на рис. 1 [6].
Рис. 1. Средние годовые (вверху) и сезонные аномалии температуры приземного воздуха (°С), осредненные по территории России, 1936–2024 годы [6]. Аномалии рассчитаны как отклонения от среднего за 1991–2020 годы. Показаны также 11-летнее скользящее среднее, линейный тренд за 1976–2024 годы с 95 %-ной доверительной полосой, b – коэффициент тренда (°С/10 лет), D (%) – вклад тренда в суммарную дисперсию
Важно отметить, что на фоне достаточно устойчивой тенденции к потеплению по территории РФ в целом, в отдельные годы в различных регионах образуются обширные зоны, в которых среднемесячная (или средняя за зиму) температура оказывается в среднем на 3–8 °С ниже нормы (рис. 2). При этом изменения температуры по территории РФ происходили неравномерно. Например, в 2019–2022 годах минимум потепления в среднем за год был отмечен на юге Сибири, где зимой наблюдалась область незначительного уменьшения температуры, а в летний и осенний периоды ее повышение. В центре Сибири в осенний период происходило незначительное повышение температуры. В 2023 году минимум потепления в среднем за год наблюдался не только на юге Сибири, но и на востоке Якутии.
Следует отметить, что за период 2019–2023 годов на территории России в целом наблюдалась тенденция к увеличению годовых сумм осадков: тренд составлял 1,8–2,2 % нормы/10 лет [1–5]. При этом наиболее значительный рост сезонных сумм осадков в целом по территории России наблюдался весной (5,1–5,9 % нормы/10 лет). Изменение количества осадков происходило крайне неравномерно, и в различные годы на территории РФ появлялись области, где количество осадков уменьшалось, а в ряде регионов наблюдались засухи. Так, в 2019 году в Северо-Западном федеральном округе выпало 131 % нормы, а в Северо-Кавказском федеральном округе год был одним из самых «сухих» [1]. Уменьшение количества летних осадков отмечалось в 2019–2022 годах в центральных и южных регионах Европейской части России. В 2020 году продолжительные и сильные засухи были на юге и юго-западе Приволжского федерального округа, на большей части Южного федерального округа и на юге Уральского федерального округа. В сентябре необычайно сильная засуха была зафиксирована на юге европейской части России [2]. В 2021 году летом атмо-сферные засухи наблюдались во многих областях Приволжского федерального округа, в ряде областей Центрального федерального округа, на Южном Урале, чему способствовали и летние температурные аномалии: в Центральном федеральном округе они составили 3,42 °С, в Приволжском федеральном округе – 3,33 °С [2]. Сильный дефицит осадков наблюдался в Саянах и в районе Обской губы. Следует особо отметить «сухую» осень в Западной Сибири, где выпало только 82 % нормы, и засушливые условия летом в Европейской части России (83 % нормы) в основном за счет «сухого» августа, когда выпало 50 % нормы осадков [2].
Рис. 2. Аномалии среднемесячной температуры воздуха в декабре 2019, 2021 и 2022 года [1, 3, 4]
Во все сезоны средняя по территории РФ скорость ветра за период 2019–2023 годов незначительно уменьшалась [1–5]. На всей территории страны преобладали отрицательные аномалии числа дней со скоростью ветра ?15 м/с.
Отмеченные изменения климатических параметров привели к необходимости пересмотра СП 131.13330.2020 «Строительная климатология».
При принятии решения о пересмотре Свода правил особое внимание было уделено обеспеченности актуальной климатической информацией  регионов Российской Федерации. Этот фактор стал одним из ключевых аспектов, определяющих необходимость внесения изменений в действующие нормы.
Подготовка проекта пересмотра Свода правил осуществлялась на основании материалов научно-исследовательской работы «Мониторинг достаточности климатической информации для целей проектирования, включая проектирование инженерных сооружений и объектов строительства, в разных регионах Российской Федерации». В ходе работы был проведен анализ расположения действующих метеостанций в пунктах, включенных в СП 131.13330.2020 «СНиП 23-01-99* Строительная климатология», которые в тот момент времени предоставляли климатическую информацию для проектирования и строительства.
акже был подготовлен перечень пунктов из СП 131.13330.2020 «СНиП 23-01-99* Строительная климатология», в которых метеостанции по разным причинам закрылись. Была проведена систематизация регионов и территорий по достаточности и недостаточности обеспечения климатической информацией для строительства. В результате проведенного анализа Свода правил выпуска 2020 года было установлено, что оптимальную обеспеченность климатической информацией в РФ имеют только восемь регионов, где расстояние между метеостанциями составляет до 100 км [7]. К ним можно отнести Донецкую Народную Республику и Луганскую Народную Республику, а также Республику Адыгея, Республику Ингушетия, Республику Крым, Республику Северная Осетия – Алания, Сахалинскую область. Минимальная обеспеченность отмечена в 17 регионах, остальные 60 регионов имеют недостаточную обеспеченность климатической информацией [7]. В связи с этим при пересмотре свода правил на основе проведенного анализа для каждого региона РФ в документ были введены новые пункты с данными о специализированных климатических параметрах. Например, в Тульской области не была охвачена климатической информацией южная часть. Поэтому в СП 131.13330.2025 введена новая станция – Волово.
Таким образом были проанализированы все регионы РФ, и в результате проведенного мониторинга в СП 131.13330.2025 было добавлено 110 пунктов к существующим 440. При этом все специализированные климатические параметры по этим 440 пунктам были пересмотрены.
В табл. 1–3 приведены значения специализированных параметров для холодного периода года (табл. 1), для теплого периода года (табл. 2) и средние месячные и годовая температура воздуха (табл. 3) из пересмотренного документа.
При проектировании зданий в различных регионах РФ необходимо определить, к какому климатическому району для строительства относится тот или иной населенный пункт, в котором планируется строительство. Для установления климатического района для строительства используется сочетание средней месячной температуры воздуха в январе и июле, средней месячной относительной влажности воздуха в июле и средней скорости ветра за три зимних месяца. Ранее в СП 131.13330.2020 данные по средней месячной скорости ветра отсутствовали и была сложность с определением климатического района для строительства. Введение новой таблицы с данными по скоростям ветра позволит определить климатический район для строительства для большего количества населенных пунктов без обращения в районные УГМС за данными по средней месячной скорости ветра за три зимних месяца. Также в СП добавлена таблица с данными о средних месячных и годовой сумме осадков. Однако карта Схематического районирования для строительства из-за крайне жестких сроков выполнения работы не была пересмотрена. Вместе с тем в связи с наблюдаемыми изменениями климата границы климатических зон подверглись некоторым изменениям. Исходя из этого, настоятельно рекомендуется определять климатический район для осуществления строительных работ, руководствуясь табл. A.1 «Климатические критерии районов для строительства», содержащейся в Своде правил СП 131.13330.2025 «Строительная климатология».
При пересмотре Свода правил были переработаны существующие карты схематического районирования и добавлены следующие новые карты-врезки: схематическая карта распределения среднего за год числа дней с переходом температуры воздуха через 0 °С и карта-врезка для Южного федерального округа; схематическая карта районирования по величине удельной энтальпии I с обеспеченностью 0,95, кДж/кг (параметр А), и с обеспеченностью 0,98, кДж/кг (параметр Б); карты-врезки для Южного федерального округа и территории Дальнего Востока, а также новая схематическая карта районирования по продолжительности периода с устойчивыми морозами, дни (рис. 3).
Рис. 3. Схематическая карта районирования по продолжительности периода с устойчивыми морозами, дни
Основой для расчета климатических параметров послужили данные ФГБУ «Всероссийский научно-исследовательский институт гидрометеорологической информации – Мировой центр данных» (ВНИИГМИ–МЦД) за период 1973–2022 годов. Экстремальные значения климатических параметров (абсолютная минимальная и абсолютная максимальная температуры воздуха, суточный максимум осадков, максимальная амплитуда температуры воздуха) выбраны из экстремальных суточных значений за весь период наблюдений на метеорологических станциях.
Проведенный пересмотр Свода правил по строительной климатологии обеспечит применение современных и точных климатических данных в расчетах. Это даст возможность создавать проекты ограждающих конструкций, систем отопления и кондиционирования зданий, а также систем инженерного обес-печения с учетом реальных климатических условий. В итоге это поможет оптимизировать расход материальных и энергетических ресурсов, минимизировать вероятность излишнего потребления. Обновленные климатические показатели помогут снизить риск ущерба от неблагоприятных погодных явлений.
Приказом Минстроя России от 8 августа 2025 года № 470/пр СП 131.13330.2025 «СНиП 23-01-99* Строительная климатология» был утвержден. Этот свод правил вступил в силу с 9 сентября 2025 года взамен предыдущей редакции СП 131.13330.2020 «Строительная климатология».
1. Доклад об особенностях климата на территории Российской Федерации за 2019 год. – М.: Росгидромет, 2020.
2. Доклад об особенностях климата на территории Российской Федерации за 2020 год. – М.: Росгидромет, 2021.
3. Доклад об особенностях климата на территории Российской Федерации за 2021 год. – М.: Росгидромет, 2022.
4. Доклад об особенностях климата на территории Российской Федерации за 2022 год. – М.: Росгидромет, 2023.
5. Доклад об особенностях климата на территории Российской Федерации за 2023 год. – М.: Росгидромет, 2024.
6. Доклад об особенностях климата на территории Российской Федерации за 2024 год. – М.: Росгидромет, 2025.
7. Отчет о научно-исследовательской работе «Мониторинг достаточности климатической информации для целей проектирования, включая проектирование инженерных сооружений и объектов строительства, в разных регионах Российской Федерации». – М., 2023.
