Подбор регулирующих клапанов для вентиляционных установок. Режим работы – постоянный
Selection of Pressure Control Valves for Fan Units.  Work Mode – Continuous
M. M. Savchenko, Leading Design Engineer, OJSC "IPROMASHPROM"
Keywords: automatic control valve, heat transfer media, heat transfer media temperature schedule
The greatest share of the automatic control valves is occupied by the products designed following the traditions of West-European countries.  One of them is adaptation of the product construction for the so called modular repair, when the entire unit containing the broken part is replaced instead of just the part itself.  The valve construction is designed not only for simultaneous expiration of service life of majority parts in a unit, but also for convenient replacement of units without engagement of high-paid and highly qualified staff.  Such construction solution is very convenient and advantageous in case of long-term operation of the valve, when the units work for their entire service life before replacement.  However if a valve operating conditions are far from optimal, its service life ends up being much shorter than designed, wear of the unit parts will be uneven, and modular repairs - expensive.  One of the reasons for reduction of the service life is frequent activation of the valve electrical drive, which occurs as a result of excessive changes in heat supply with each change of the position (step) of the valve.  Non-optimal work conditions make installation of such valves inefficient.
В настоящее время основную часть рынка автоматических регулирующих клапанов занимают изделия, спроектированные в традициях западноевропейских стран. Одной из них является приспособление конструкции изделия к так называемому агрегатному ремонту, при котором заменяется не только деталь, вышедшая из строя, но весь узел, включающий эту деталь. Конструкция клапана предусматривает не только одновременную выработку ресурса большинства деталей узла, но и удобную замену узлов без привлечения высокооплачиваемого и высококвалифицированного персонала. Такое решение конструкции очень удобно и выгодно при условии долговременной работы клапана, когда узлы до замены отрабатывают весь срок предусмотренный службы. Если же условия работы клапана далеки от оптимальных, то срок его службы оказывается значительно меньше предусмотренного конструкцией, износ деталей узла неравномерным, а агрегатный ремонт – дорогостоящим. Одной из причин сокращения срока службы является частое срабатывание электропривода клапана, что бывает в результате слишком большого изменения подачи тепла при каждом изменении положения (шаге) клапана. Неоптимальные условия работы делают невыгодной установку подобных клапанов.
Статья опубликована в журнале “АВОК” за №3'2018
